cd drive not recognised
windows xp sudddenly wont recognise the internal cd drive. it says drivers are found but the device not found. the device appears in the device manager but with little yellow "!" mark. the cd drive icon which use to be in "my computer" is gone and only a funny little shortcut on the desktop which wont work if click it.
anyone who had similar problem before???
thanks for your help in advance
Have you made any recent changes to your machine - inside or outside, software or hardware?
May be worth checking that all connectors to the errant drive are fully pushed home.
Have you tried a System Restore to a time when the device was working properly?
Optical drives are by far from being robust pieces of equipment and can die without any apparent fault or warning. Do you have a spare drive that you could replace your current one with to check that it hasn't gone to the great electronic dumping ground in the sky?
A new drive - even a DVD RW - would not be particularly expensive so if it is the drive that has met its demise, it isn't worth spending time and money trying to repair it.
