persianpower Posted January 11, 2005 Report Share Posted January 11, 2005 Hey everytime im running multiple programs - i recieve a MEMORY breakdownI have a P4 with 512 ram - everything works great right after a windows boot but after several hours - the system slows down until it eventually becomes unresponsive (except for the mouse which for some reason always seems to move when i say so).Anyways here is what the EVENT VIEWER has to say - if anyone can identify my problems - id be very much indebited if youd help me resolve them thanks. Ive also attached DR watson log if that helps.System errors in Event viewer EVENT # 7000 & 7001 (THESE ONES REPEAT A LOT)Source: Service Control Manage 1) The NTPort Library Driver service failed to start due to the following error: The system cannot find the file specified. 2) The AMON service failed to start due to the following error: The system cannot find the file specified. *this doesnt make sense, AMON is part of NOD32 virus scanner - ive uninstalled and deleted almost all remnants of this progam from my computer.* Except for one .dll file which wont delete3) The Sentinel service depends on the Parallel port driver service which failed to start because of the following error: The service cannot be started, either because it is disabled or because it has no enabled devices associated with it. *ive gone ahead an changed this to automatic in services.msc" Errors 7000 & 7001 repeat frequently.The system doesnt reboot or show a blue screen, rather it freezes itself with an immediate and unexpected surge in Processer and Ram (both reach thier peaks, overload and freeze). I can move the mouse, but everything on the desktop becomes nonresponsive, cpu reaches 100%, the shell collapses (sometimes it automaticlly restatrs itself). DC++ loses connection. a restart sets everything back to normal until another immiment future crash (usually when im multitasking). Quote Link to comment Share on other sites More sharing options...
persianpower Posted January 11, 2005 Author Report Share Posted January 11, 2005 sorry i forgot to attach dr watson log - here is just a couple of the latest - i have dr watson in my startup folder and its always running to check to see what goes wrong*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\WINDOWS\system32\ntdll.dll - function: ntdll!KiFastSystemCallRet 7c90eb89 90 nop 7c90eb8a 90 nop ntdll!KiFastSystemCall: 7c90eb8b 8bd4 mov edx,esp 7c90eb8d 0f34 sysenter 7c90eb8f 90 nop 7c90eb90 90 nop 7c90eb91 90 nop 7c90eb92 90 nop 7c90eb93 90 nop ntdll!KiFastSystemCallRet: 7c90eb94 c3 ret 7c90eb95 8da42400000000 lea esp,[esp] 7c90eb9c 8d642400 lea esp,[esp] 7c90eba0 90 nop 7c90eba1 90 nop 7c90eba2 90 nop 7c90eba3 90 nop 7c90eba4 90 nop ntdll!KiIntSystemCall: 7c90eba5 8d542408 lea edx,[esp+0x8] 7c90eba9 cd2e int 2e*----> Stack Back Trace <----**** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\WINDOWS\system32\SHELL32.dll - WARNING: Stack unwind information not available. Following frames may be wrong.*** ERROR: Module load completed but symbols could not be loaded for C:\WINDOWS\Explorer.EXE*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\WINDOWS\system32\kernel32.dll - ChildEBP RetAddr Args to Child 0007ff08 7ca32c57 00000000 0007ff5c 01016e95 ntdll!KiFastSystemCallRet0007ff14 01016e95 000eb508 7ffde000 0007ffc0 SHELL32!Ordinal201+0x280007ff5c 0101e2b6 00000000 00000000 000206b6 Explorer+0x16e950007ffc0 7c816d4f 00000002 5d093c48 7ffde000 Explorer+0x1e2b60007fff0 00000000 0101e24e 00000000 78746341 kernel32!RegisterWaitForInputIdle+0x49*----> Stack Back Trace <----**** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\WINDOWS\system32\RPCRT4.dll - WARNING: Stack unwind information not available. Following frames may be wrong.ChildEBP RetAddr Args to Child 00adff80 77e76c22 00adffa8 77e76a3b 00093158 ntdll!KiFastSystemCallRet00adff88 77e76a3b 00093158 00000000 0007f88c RPCRT4!I_RpcBCacheFree+0x5ea00adffa8 77e76c0a 000a6cb8 00adffec 7c80b50b RPCRT4!I_RpcBCacheFree+0x40300adffb4 7c80b50b 000b1ca0 00000000 0007f88c RPCRT4!I_RpcBCacheFree+0x5d200adffec 00000000 77e76bf0 000b1ca0 00000000 kernel32!GetModuleFileNameA+0x1b4*----> Stack Back Trace <----*WARNING: Stack unwind information not available. Following frames may be wrong.*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\WINDOWS\system32\ole32.dll - ChildEBP RetAddr Args to Child 00b2ff78 7c802451 0000ea60 00000000 00b2ffb4 ntdll!KiFastSystemCallRet00b2ff88 774f2fcb 0000ea60 000b4438 774f314d kernel32!Sleep+0xf00b2ffb4 7c80b50b 000b4438 7c910945 7c91094e ole32!StringFromGUID2+0x2d100b2ffec 00000000 774f319a 000b4438 00000000 kernel32!GetModuleFileNameA+0x1b4*----> Stack Back Trace <----*WARNING: Stack unwind information not available. Following frames may be wrong.ChildEBP RetAddr Args to Child 00baffb4 7c80b50b 00000000 ffffffff 7c90fb71 ntdll!KiFastSystemCallRet00baffec 00000000 7c92798d 00000000 00000000 kernel32!GetModuleFileNameA+0x1b4 Quote Link to comment Share on other sites More sharing options...
nellie2 Posted January 12, 2005 Report Share Posted January 12, 2005 I can't pretend I understand all that lot... but it looks like windows is looking for files and not able to find them.Have you run system file checker? Quote Link to comment Share on other sites More sharing options...
