Esben Posted January 27, 2005 Report Share Posted January 27, 2005 Running XP w/wireless network, type D-link.At several instances my network connection is blocked. The blocking is total, and restart of XP is NOT sufficient, I have to use the system recovery procedure using an "earlier" date for recovery.It seems to me that the problem occures if the Medai player is started, but I'm not sure.Anybody have a clue??THANKS.....Esben :unsure: :unsure: :unsure: Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted January 27, 2005 Report Share Posted January 27, 2005 Can you describe your network topologya little more? Is it just one computer or laptop connected wirelessly to the router?Do you use any antivirus or spyware removal/protection software? Quote Link to comment Share on other sites More sharing options...
Esben Posted January 28, 2005 Author Report Share Posted January 28, 2005 The configuration is as follows:2 computers wireless connected to a D-link type DI-624, however, I'm Quite sure that it is a computer problem. When I logg the traffic from the affected computer, it seems like it keeps sending, but do not receive eanything. The second PC is up running without problems.All kinds of "network" commands from the sick PC is not working.i.e. the ping command.Software:XPSP2-Home, Panda platinum, spysweeper.Firewalls activated, tryed to turn them off, but did not help.Thanks for assisting me!!!!BRGEsben Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 28, 2005 Report Share Posted January 28, 2005 If you go to Start->Control Panel->Network & Internet Connections->Network ConnectionsYou should se "Wireless Connection" - right click it, and select "View Available Wireless Networks"Is the network listed there? Quote Link to comment Share on other sites More sharing options...
Esben Posted January 28, 2005 Author Report Share Posted January 28, 2005 Yes!The PC also informs me that I'm connected to the network, but I'm not,I cant see eanything on the network, and the network cant see me. Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted January 28, 2005 Report Share Posted January 28, 2005 Did it work at one time, then stop? Did you make any changes to any security settings on the Router or the PC that could have caused this behavior? Any changes to the wireless settings? Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 31, 2005 Report Share Posted January 31, 2005 Please check this:let us know the following information:The IP Address of your routerThe output of "ipconfig /all"To do this, go to Start, select "Run"Type in cmdYou'll some to a prompt that looks similar (not exaclty) to this:C:\Documents and Settings\User\>Type this in:ipconfig /all > C:\output.txtNow paste the contents of C:\output.txt in here, make sure to enclose it inside of this: [code] TEXT GOES HERE [ /code]Just so you know, the output should be similar to this:Windows 2000 IP Configuration Host Name . . . . . . . . . . . . : WBLTQ14 Primary DNS Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : CENSOREDEthernet adapter Local Area Connection: Connection-specific DNS Suffix . : CENSORED Description . . . . . . . . . . . : VIA Rhine II Fast Ethernet Adapter Physical Address. . . . . . . . . : 00-0A-E6-9A-74-AB DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 10.129.20.164 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 10.129.20.1 DHCP Server . . . . . . . . . . . : 10.129.0.52 DNS Servers . . . . . . . . . . . : 10.129.0.52 10.132.0.52 Primary WINS Server . . . . . . . : 10.129.0.52 Lease Obtained. . . . . . . . . . : Monday, January 10, 2005 3:07:11 AM Lease Expires . . . . . . . . . . : Monday, January 10, 2005 1:07:11 PM Quote Link to comment Share on other sites More sharing options...
