dragonrice Posted January 31, 2005 Report Share Posted January 31, 2005 stop:C000218{registry file failure}the registry cannot load hive(file)\systemroot\system32\config\softwareor it's log or alternateIt is corrupt, absent, or not writablebeginning dump of physical memorydumping physical memory to disk: 1-----------------------------------------i get that error when i start up my pc. i tried system restored doesn't work. I dont have a windows xp cd so i dont kno how to install recovery console to fix this. Please help!! i have a windows recovery cd from the manufacturer when i bought the computer but i dont kno how to use it because windows doesnt startup. running on windows xp home edition :( :( Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 1, 2005 Report Share Posted February 1, 2005 Try to boot with the recovery CD. You may need to change the BIOS boot sequence first, to have the CD-ROM before the HD. Quote Link to comment Share on other sites More sharing options...
scuzzman Posted February 1, 2005 Report Share Posted February 1, 2005 Also - have a run with RegScrubXP... Quote Link to comment Share on other sites More sharing options...
