n1ghts Posted February 1, 2005 Report Share Posted February 1, 2005 HiI am going to make 4 pCs with wireless connection. Hardwares are Belkin broadband modem wireless router and 4 desktops with wireless network cards. The building condition as below 2 PCs in one room (secluded with walls and a door) with the Internet connection and thats where I am going to put the router obviously....and one PC is in the next room.....my question is that can the 2nd floor PC get connected if there are 2 doors blocking the router signal and there are also one extra door to take the stairs to go to the room in the 2nd floor, I am just wondering whether it can reach the connection there...This is my first time implementing wireless....I just need re-assurance for my confidence in implementing this type of network..Thanks in advanced Quote Link to comment Share on other sites More sharing options...
Redhat Posted February 1, 2005 Report Share Posted February 1, 2005 Don't worry, it'll work :) (Should do anyway!!!) Quote Link to comment Share on other sites More sharing options...
n1ghts Posted February 1, 2005 Author Report Share Posted February 1, 2005 Is there any possibility that it cant reach from the 2nd floor so that I have to buy AP (Access Point) hardware?Thx Quote Link to comment Share on other sites More sharing options...
scuzzman Posted February 1, 2005 Report Share Posted February 1, 2005 No, just buy Wireless-G routers and NIC's, you'll be fine. I think, and someone might want to verify this, but G has a like 500 foot range...You should be fine... but don't forget to secure your wireless network, there are tutorials on this site for that. Quote Link to comment Share on other sites More sharing options...
n1ghts Posted February 1, 2005 Author Report Share Posted February 1, 2005 Thx ScuzzmanI had Belkin router in mind http://www.novatech.co.uk/novatech/specpage.html?BEL-F5D763which I am going to purchase soon. Quote Link to comment Share on other sites More sharing options...
Bluecow Posted February 1, 2005 Report Share Posted February 1, 2005 I've got a belkin F5D7230-4 it's just the wireless router and it gives a excellent (according to the lappy) to the signal to and from the router.The instructions you get are rubbish and don't include any security precautions. Quote Link to comment Share on other sites More sharing options...
n1ghts Posted February 1, 2005 Author Report Share Posted February 1, 2005 I have one more question, I know that it is not wise to enable printer and file sharing using netbios if we have switch/hub between LAN and the broadband modem. My question is that is it ok to enable netbios for the PC A directly connected to broadband router with ethernet cable whilst the other PCs using wireless network card being enabled for their netbios with printer and file sharing. I know that Belkin which I gave the link above has 4 switch port, suppose PC A is connected to Internet using Ethernet cable to one of the swicth ports for the broadband router.Please enlighten me, thanks in advanced. Quote Link to comment Share on other sites More sharing options...
scuzzman Posted February 2, 2005 Report Share Posted February 2, 2005 I have one more question, I know that it is not wise to enable printer and file sharing using netbios if we have switch/hub between LAN and the broadband modem. My question is that is it ok to enable netbios for the PC A directly connected to broadband router with ethernet cable whilst the other PCs using wireless network card being enabled for their netbios with printer and file sharing. I know that Belkin which I gave the link above has 4 switch port, suppose PC A is connected to Internet using Ethernet cable to one of the swicth ports for the broadband router.Please enlighten me, thanks in advanced.This shouldn't be much of a problem if you make sure to enable the NAT/Firewall inside the Belkin. Quote Link to comment Share on other sites More sharing options...
n1ghts Posted February 2, 2005 Author Report Share Posted February 2, 2005 I see. Thx for the assurance scuzzman Quote Link to comment Share on other sites More sharing options...
