lululovesu Posted February 6, 2005 Report Share Posted February 6, 2005 :blink: OK...I am totally confused. First of all I do not know what Java is and what it does, and why I would need it. I apparently (from what I can tell) I did not have it before because I downloaded it from Java.com and now I have an icon. But, from what I am reading, I should have downloaded it from Sun.com???? I can't figure out how I have some "virus" when I didn't have that system...unless it is hidden in Microsoft 98 on my computer somewhere.Please spell this out for me. How do I clear this "virus"? Where and what am I suppose to download??BTW.....The Java.com version slowed my computer down so much that I can hardly get my computer to start without an error!!Whoever answers this (if you can and will) probably has their work cut out for them; hence, the reason I wonder if someone will respond. :huh: Thanks.....LOST LuLu Quote Link to comment Share on other sites More sharing options...
trackrat Posted February 6, 2005 Report Share Posted February 6, 2005 Java technology allows certain types of programs, called Java applications or Java applets, to run on Windows-based computers.It should be in your add & remove programs, so you can uninstall it from there.Try this site if you want to download it again.http://www.anfyteam.com/java/If you cannot uninstall it try this little program.http://www.nirsoft.net/utils/myuninst.html Quote Link to comment Share on other sites More sharing options...
djohn Posted February 7, 2005 Report Share Posted February 7, 2005 Hello lululovesu :) Java should not have slowed down your system to the extent you say. So, maybe you do have something else that is causing the problem. Click on this link for instructions to download Highjackthis application. Here then post your log to this section of the forum for our experts to check over. Here Quote Link to comment Share on other sites More sharing options...
