Ripping CDs using EAC and LAME
D4\/!d
Nero should do it but if not you could try Exact Audio Copy with Lame :-
Switch  Exact Audio Copy to use LAME external encoder and from the encoder settings page, choose "high quality".
This should enable very good quality settings (known as '--alt-preset standard'). Now you can use EAC to copy ( or CD) MP3s, to WAVs or to compress WAVs to MP3s.
Exact Audio Copy From
http://www.afterdawn.com/software/audio_so..._audio_copy.cfm
LAME MP3 Encoder 3.92 From
http://www.rarewares.org/mp3.html
Edit spelling R4
Hello r4may, I see you use the same combination as I do. (Although I am still flitting between lame-3.90.3 and lame-3.97a5. Cannot decide which I prefer). How do you get on with it? Do you also use Foobar to listen to your wonderfully made MP3s. B)
