Problem with CHKDSK
I have one laptop with Win2K. When I do a CHKDSK (on reboot), Windows starts loading, then the screen gets completely black. I can see the HD light flicker for several minutes, then the thing reboots.
I *assume* that it performed the CHKDSK during that blackout time, but why I do not see anything? The same thing happens if I do a Diskeeper boot-time defrag. Just black.
Any ideas? (B.t.w. it's a DELL Inspiron 2600).
I cannot offer a solution, but something is definitely wrong. I always set CHKDSK to correct any errors, and I see a blue screen showing five phases. The whole thing usually takes about ten minutes. When I run a boot time def rag with Diskeeper, it runs three phases of CHKDSK, followed by five phases of def rag, and again takes up to about ten minutes on a blue screen.
Since posting the above, I have run boot time defrag again. It only took about three or four minutes. It obviously varies according to the degree of defragmentation. It was however on a blue screen and each phase was there to see.
