Guest chedv Posted March 2, 2005 Report Share Posted March 2, 2005 Hi, my ISP has recently moved from a static ip to a dhcp system I think. I live in a rural area and it is wireless internet. From the receiver it comes down an ethernet cable into the ethernet port. I don't have a modem or anything. I first set up my router to the specific ip but now it changes. I tried letting the router connect through dhcp but get this: Login Type: DHCP Internet IP Address: 0.0.0.0 Subnet Mask: 255.255.255.0 Default Gateway: 0.0.0.0 Primary DNS: 0.0.0.0 Secondary DNS: 0.0.0.0 My router isn't accepting the internet for some reason, any ideas? Thanks alot Quote Link to comment Share on other sites More sharing options...
scuzzman Posted March 2, 2005 Report Share Posted March 2, 2005 Have you tried powercycling the router?If that doesn't do it, hook a computer to the ethernet cable adn see if it pulls an ip. Quote Link to comment Share on other sites More sharing options...
Guest chedv Posted March 2, 2005 Report Share Posted March 2, 2005 No, i haven't tried powercycling yet? If I plug the ethernet cable directly to the computer, the computer accepts it and the internet works. But when I plug it into the linksys it won't register. Quote Link to comment Share on other sites More sharing options...
scuzzman Posted March 2, 2005 Report Share Posted March 2, 2005 Here's what I'd do:1: Plug in the ethernet to the router, pull the power plug, wait 60 seconds, plug it back in and test it (powercycle).then2: Reset the router and try it again.then3: Replace the router. Quote Link to comment Share on other sites More sharing options...
