problem with Borland C++ builder 5.5
Hi, I'm trying in to run a program in c++ using Borland C++ builder 5.5. When I try to compile the program, there is an error that says that I can't use main() as a function. I trying to use the main() function to go back to main. for example,
#include<iostream.h>
#define SIZE 256
void main()
char n, quit;
cin.getline(n, SIZE, '\n');
if(strcmp(n, "Kyosuke") == 0)
cout<<"It matches!"<<"\n";
else
main();
while(quit != 'q')
cout<<"Press 'q' to exit the program. ";
cin>>quit;
This main() function works all the time until I'm using Borland. I really want use this function because it's better this way. Is there a way to fix this problem.
Hello again, Hattori-san! I don't know Borland C++, so I will just ask you if it is allowed to recursively call the main() function? I know that recursive calls in C/C++ are usually allowed, but I am not sure about main().
Actually I have just done a Google search, and from this article and others it appears as if recursive calls to main() are allowed in C, but not in C++.
#include
#define SIZE  256
void main()
    char n, quit;
    cout
    else
    main();
    while(quit != 'q')
        cout
        cin>>quit;
While you can recursively call main(), it's widely disapproved of, and not ANSI-compliant.
That said, I might reccomend this approach:
#include <iostream>
#define SIZE  256
int main() // main() should usually return an int for OS cross-compatibility
   char n[SIZE], quit;
    quit = "0"; // Defines quit so program will execute properly
   while ( quit != 'q') {
      cin.getline( n, SIZE, '\n' );
      if( strcmp( n, "Kyosuke" ) == 0 )
         cout << "It matches!" << endl;
      else
         cout << "No Match" << endl; // You can do whatever you want here...
         quit = "1"; // Assures quit != 'q' so execution continues
      cin>>quit;
      if (quit = 'q') {
          return 0; // force execution to stop
return 0; //program exit
Encapsulating it all in a while() loop keeps you from having to recursively call main().
