bikemadgrandad Posted May 2, 2005 Report Share Posted May 2, 2005 I've been using AVG7 for some time and am very pleased with it! Yesterday when opening the program an alert box came up saying 'unfinished update has been detected and the computer must be re-started to complete it' I tried re-start with no success. If you do not re-start the main screen for AVG7 appears and an attempt to check for updates results in an alert saying update was un-successful. I tried to un-install and re-install but this did not help matters. Does anyone have any ideas about this? I'm running Win 98se on an Athlon cpu. Link to comment Share on other sites More sharing options...
scuzzman Posted May 2, 2005 Report Share Posted May 2, 2005 Have you tried manually checking for updates? Link to comment Share on other sites More sharing options...
dadyassa Posted May 2, 2005 Report Share Posted May 2, 2005 Mine is set to auto update, but just got one on manual. virus database 517 (17165 bytes) Link to comment Share on other sites More sharing options...
djohn Posted May 3, 2005 Report Share Posted May 3, 2005 It sounds very much as though you have a corrupt file that is stopping the update. Updates are coming through nearly every day this past month or so. I suggest you download a fresh version to your desktop then log off line, do a complete un-install of your current version reboot your PC then install from the fresh download. :unsure: Link to comment Share on other sites More sharing options...
bikemadgrandad Posted May 3, 2005 Author Report Share Posted May 3, 2005 I think I must have had a senior moment when I posted this because when I checked the FAQ on Grisoft web-site, the answer was staring me in the face. There was a file 'WAIT4SD' which I had to delete. Thanks to all who took the time to think about this for me. :wub: :wub: Link to comment Share on other sites More sharing options...
scuzzman Posted May 3, 2005 Report Share Posted May 3, 2005 Thank you for posting your resolution! Link to comment Share on other sites More sharing options...
scuzzman Posted May 3, 2005 Report Share Posted May 3, 2005 This topic has now been resolved and subsequently closed.If you wish to add a reply, please contact an administrator or moderator to reopen the topic. Link to comment Share on other sites More sharing options...
