ike Posted May 11, 2005 Report Share Posted May 11, 2005 Lately whenever I click on a link, that opensin the same page all I get is a blank page.I can copy and past the address and it links ok.When I click on a links that open in a different pageit works ok...Any idea what caused this.. :blink: I run Win.98se . IE 6 Quote Link to comment Share on other sites More sharing options...
aditya Posted May 11, 2005 Report Share Posted May 11, 2005 ya its problem with settings of ur IE6restore default settingsand then save settingsotherwiseclick link with right button and open it with new windowfirst one will be the good sol. Quote Link to comment Share on other sites More sharing options...
ike Posted May 11, 2005 Author Report Share Posted May 11, 2005 Nope..Still have to copy shortcut and past it inthe address bar to get page to open..?Thanks anyway .. aditya... Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted May 12, 2005 Report Share Posted May 12, 2005 Open windows explorer. Tools > Folder Options. Click File Types and restore defaults there as well. I cant remember win98 very well so I can at least bump this. Quote Link to comment Share on other sites More sharing options...
ike Posted May 12, 2005 Author Report Share Posted May 12, 2005 I don't have this opion "restore defaults" in File Types ...Windows 98 se Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted May 13, 2005 Report Share Posted May 13, 2005 I think there was a way to reinstall Internet Explorer on Win98, but I don't know if this is possible with IE6. Is there an option to reinstall or repair IE from Add/Remove Programs? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted May 13, 2005 Report Share Posted May 13, 2005 If not, can you download IE6-SP1 and install it over your current installation? Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted May 13, 2005 Report Share Posted May 13, 2005 http://forums.neoplanet.co.uk/index.php?showtopic=18436 Quote Link to comment Share on other sites More sharing options...
HeddaLora Posted May 13, 2005 Report Share Posted May 13, 2005 A couple of other things that mess up browsing, which you can check, are:1. Delete all temp files & temporary internet files.2. Check for (and remove any) spyware.3. Sometimes corrupt cookies cause weird browsing problems, but generally only with the web sites associated with the particular cookie(s). Quote Link to comment Share on other sites More sharing options...
ike Posted May 14, 2005 Author Report Share Posted May 14, 2005 Thanks Everybody...I reinstalled IE6..everything OK now... ;) Quote Link to comment Share on other sites More sharing options...
technokush Posted March 18, 2006 Report Share Posted March 18, 2006 I have this same problem but on xp home sp2, I click a link, and....a white page appears, but if I copy and paste the link, it works fine, anyone know how I can fix it?, ta Quote Link to comment Share on other sites More sharing options...
