g_ballz Posted June 27, 2005 Report Share Posted June 27, 2005 ok... I have an ATI Radion AIW x800 XT, with a AMD 2800+ 64bit system, soundblaster live, 80gb harddriveI try to plug my g-card in to my TV through the HDTV connection... when I switch it to the second display, or clone it, the TV just gets all fuzzy, and everything is stretched and skewedis it alright to use regular RCA cables, as long as the colors match? because that's what I'm doing... I did it with my DVD player, plugging that in to my tv through HDTV, and it worked fineI want to know why it wont work with my computer :( can anybody help me out here? I'm really looking forward to being able to put this thing on 1600x1200thanks in advance for any help Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted June 27, 2005 Report Share Posted June 27, 2005 Is this of any help.http://support.gateway.com/s/Manuals/Deskt...20/08820c05.htm Quote Link to comment Share on other sites More sharing options...
g_ballz Posted June 27, 2005 Author Report Share Posted June 27, 2005 no... I understand how to use the regular tv displaymy problem is only with the HDTV displayI can use the regular finebut when I try to use the HDTV one, everything goes funky Quote Link to comment Share on other sites More sharing options...
