marvin_in_duckville Posted July 3, 2005 Report Share Posted July 3, 2005 I have both a D-Link wireless router and Netgear Wireless Access Point attached to my network to cover some dead areas. My PDA and a Win2000 laptop connect happily to both. A tablet PC running XP SP2 works with the router but not the AP, where I get the "limited or no connectivity" message. I've tried some of the fixes for this [assuming it's linked to the SP2 bug] to no avail. Could there be some other explanation? Quote Link to comment Share on other sites More sharing options...
scuzzman Posted July 3, 2005 Report Share Posted July 3, 2005 When you say "AP", I assume you mean your Wireless Access Point. It is normal for the Local Area Connection to read "Limited or no connectivity" when using a wireless connection, because the ethernet is not being assigned an IP address. To connect using your Tablet/AP, go to your network connections screen, right-click on the wireless connection, and select "View available wireless networks". Select the network from your AP, and click "Connect". Enter your WEP/WPA key if you have one, and you should be online. Quote Link to comment Share on other sites More sharing options...
marvin_in_duckville Posted July 3, 2005 Author Report Share Posted July 3, 2005 Hi John, thanks for your response. "Enter your WEP/WPA key if you have one, and you should be online. " - indeed I should. But I'm not. And I repeat, my PDA and Win2000 laptop connect happily to either the AP or the Router. Quote Link to comment Share on other sites More sharing options...
homecomputeraid Posted July 3, 2005 Report Share Posted July 3, 2005 Are you able to check whether the tablet PC that won't connect is 'locked' on a certain channel? The other things I'd check are SSID (which I would think would match between the Access Point and Router) and security settings. Quote Link to comment Share on other sites More sharing options...
Vasichko Posted August 25, 2005 Report Share Posted August 25, 2005 Check your WEP/WPA settings, try it with the SP2 firewall off. Also check to see if you have DHCP turned on. Quote Link to comment Share on other sites More sharing options...
