I Need Help
rabin
Can anybody help me on the following problems?
-How can i protect my computer on Local Area Network by making other users enter the password, who want to access my computer?
i.e. how can i create password in LAN for other users?
I have Windows XP SP2 installed.
thank you.
Windows does not require passwords for LAN. It assumes the password you used (or did not have to use) at login, verifies your identity. Therefore, you cannot ask for a password to access a LAN. You would require a 3rd party app to do this.
How To Set Up a File System for Secure Access in Windows 2000
EDIT:
I think I found a 3rd party app that does what you need.
SafeGuard PrivateCrypto* - http://www.utimaco.com/createframes.html?h...ucts/sg_pc.html
  • Implements the state-of-the-art encryption algorithm AES
  • ”Secure wipe“ function
  • Optional encryption of entire directory trees
  • Secure password logging
  • Protects against “brute force” attacks by increasing response times each time the user enters the wrong password
  • Keys are generated from the password entered by the user
  • Option to generate self-extracting files
  • Data compression
*Freeware for private users.
