AMD 64 problems
madboy33
Hi all
I have this problem
If i try to open a folder or even a programme, with double click, it takes i would say about 5 seconds to open. After it is open (and then closed) then it will open instantly until the next re-boot.
I can not work out what is doing it.
I have the correct drivers for my Logitech wireless Keyboard and Mouse. I have checked all the setting and they are correct.
I am starting to get a little frustrated.
Checked all settings, have even msconfig down to just a few starting.
Please help
AMD64 3000 ATIX600 PRO 256MB Graphics card. 1GB Corsair Pro ram. Windows XP Pro. 120gb SATA drive and a 180gb PATA hard drive.
Not a lot of programmes loaded at the moment
Help
