Pouria Posted October 27, 2005 Report Share Posted October 27, 2005 CPU:AMD Athlon 3500+ socket 939 64 bitMB:ASUS A8N-EGraphics:Palit Geforce 6600 256 MB 128 bit PCIEOS:XP PRO SP2Cannot resume from standbyIt seems that system switch into ON by making sounds into CASE but MONITOR's LED is blinking and shows nothingI think drivers are installed correctly and there is no USB devices attached to the System.any ideas?Thanks in advance. Quote Link to comment Share on other sites More sharing options...
trackrat Posted October 27, 2005 Report Share Posted October 27, 2005 Have you checked the power options from the control panel to make sure nothing is enabled in hibernation?.Also have you tried rebooting your computer by pressing the reset button. Quote Link to comment Share on other sites More sharing options...
Pouria Posted October 27, 2005 Author Report Share Posted October 27, 2005 With Enable HibernationThere is not any sounds into the Caseand system cannot resume Quote Link to comment Share on other sites More sharing options...
