2wire wireless router problem
jeannie
Hi. My main computer can no longer access the internet. The problem seems to be with the router drivers which wont load from the installation disk (BT Broadband). I have tried many times to reinstall the drivers but when I plug in the USB lead as instructed during the installation process the drivers fail to load properly. The other computers on the network are having no problems.
Any suggestions?
It has been suggested to me that the problem may be in the registry entries and that I need a registry expert. The problem may well lie in that there are registry entries which are not affected by uninstalling the software and the hardware but are affecting the loading of the drivers. I may need an analysis of registry entries.
Does anyone have any suggestion as to which forum I should post my query.
TIA
Hi Jeannie,
Installing USB Devices can be tricky. A PCI 10/100 Network Interface Card (NIC) will probably do the trick for you, if the 2-wire device you're connecting to has an Ethernet port you can plug into (I believe it does, but double check before buying a NIC).
Please, please, please use Antistatic procedures while installing the NIC. They're very sensitive to static. A static spark that can't be seen, heard, or felt by a human can fry a NIC. When you get the NIC, if you plan to install it yourself, get an anti-static strap too. They're inexpensive and can keep you from destroying your NIC. You just put the strap around your wrist, and attach the alligator clip to a metallic part the PC's chassis. Make sure the PC is powered off, of course, and don't attach the strap to the power supply!
