Frenk made God Posted January 2, 2006 Report Share Posted January 2, 2006 i have a problem with installation, when i try to install programs, i get error message: 'error reading setup initialization file', or 'the source file is corrupted', or illegal operation ...i don't no what to do, reinstalling my OS (Windows ME) didn't help, i tried to download few programs to fix my registry (i was thinkin that maybe registry is source of the problem), but i can't install them. is there any solution other than formatting my disk? Quote Link to comment Share on other sites More sharing options...
-pops- Posted January 2, 2006 Report Share Posted January 2, 2006 Are you installing over the top of your exisiting ME setup?You would be better off doing a clean install. That may mean reformatting the drive but you will then be certain that you are starting from a new Windows installation and any faults or errors remaining from old programs will be eliminated.Yes, it is more complex and will take longer but it will be better for it. Quote Link to comment Share on other sites More sharing options...
Frenk made God Posted January 2, 2006 Author Report Share Posted January 2, 2006 ok, i'll do it Quote Link to comment Share on other sites More sharing options...
Frenk made God Posted January 3, 2006 Author Report Share Posted January 3, 2006 i formatted c: drive and installed windows again, but i still have same problem. is it possible that i have some error or something on d: partition that can cause this problem and i have to format d: ? Quote Link to comment Share on other sites More sharing options...
-pops- Posted January 3, 2006 Report Share Posted January 3, 2006 You are best reformatting all of the drive - removing old partitions as well and start (effectively) from a whole clean drive. Quote Link to comment Share on other sites More sharing options...
