Dan12 Posted February 28, 2006 Report Share Posted February 28, 2006 Hi, Have an older pc my son gave to me that has windows 98se on, and sound was working ok.Because there was that much junk on there i decided i would reinstall windows, I have the origanal discs thatcame with the pc and drivers also.Reformatted and did the install ok, loaded the drivers from origanal disc ok but have no sound have been into control panel and checked sound is not muted or low volume and all is ok.also checked that all the drivers had installed ok and no conflicts and all are working ok.any ideas would be appreciatedThanks Quote Link to comment Share on other sites More sharing options...
-pops- Posted February 28, 2006 Report Share Posted February 28, 2006 Is this on-board sound or a separate sound card?Are the speaker connections in the correct sockets?Have you tried different speakers or headphones? Quote Link to comment Share on other sites More sharing options...
Dan12 Posted February 28, 2006 Author Report Share Posted February 28, 2006 Hi pops,sorry yes this is integrated sound no sound card, only cards on mobo is the internal modem and a graphicscard or some sort of ram chip altera is printed on this card this information relates to this card........media-H rev:1.2SB6 This bit of information was on the card. This card has a power connecter, a 40pin IDE connection that goes to the second IDE controller, and it has a smaller ribbon cable which is about 15mm /1/2 inch wide. speaker connections in correct sockets ,have not tried different speakers as yet but the sound was working ppre re-install.Operating System System ModelWindows 98 SE (build 4.10.2222) IBM 2142S47System Serial Number: 55214B4Enclosure Type: Mini-TowerProcessor a Main Circuit Board b300 megahertz Intel Pentium II32 kilobyte primary memory cache512 kilobyte secondary memory cache Board: IBM SPRBus Clock: 66 megahertzBIOS: IBM Aptiva BLXUK4K 02/02/98Drives Memory Modules c,d4.21 Gigabytes Usable Hard Drive Capacity3.96 Gigabytes Hard Drive Free SpaceGENERIC CRD-BP1500P [CD-ROM drive]MATSHITA CD-ROM CR-585Generic floppy disk drive (3.5") hope this has helped and not confused. Quote Link to comment Share on other sites More sharing options...
