Memory for system restore?
That all depends on how often you use system restore, or if you use 3rd party backup software.
If you have an 18GB hard drive, and you are using 12% for system restore, you are using approximatley 2GB for System Restore.
If you use 3rd party backup software, you can turn system restore off completley. If you do not, it may be a good idea to leave it enabled.
I found this which has some good information on System Restore near the bottom of the page.
