How to go about wiping a hard drive
What I would try first is to login as 'Administrator' with an empty password. Most people I know leave their Administrator account unprotected with a password.
If this fails you may have no other choice than to install XP from scratch. In a way this is preferable, as you may not want a cluttered Windows system from someone else.
Boot into the XP install CD-ROM, then follow the instructions on how to format the HD and install Windows XP.
If the CD-ROM does not boot, you may have to configure the BIOS boot sequence, so that the CD-ROM comes in first.
Let us know if you have further questions.
I think what pat is saying (I might be wrong) IS that when you boot your computer keep pressing F8 Then choose safemode from there you go to admin account then you go to control pannel user accounts you select the login that is password protected and remove password.
