RyanTheWizard Posted March 26, 2006 Report Share Posted March 26, 2006 It is not messed up cables or a messed up drive. I just bought a new one and still nothing." Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"It says that under the device properties. I got WinXP pro and the drive is a Sony DVD-RW DRU-820A drive. I don't know why it is not working. In the BIOS it sees the drive and says nothing is wrong with it. Windows device manager sees it also but says that quote above. It also says something about a problem during installation and it might not work properly. I have disabled/uninstalled like 3 times and it still dosen't work. Maybe it has something to do back when i changed the RAM timings and my computer wouldent boot and would not see my HDD. SO i cleared my cmos and it worked fine. Because that is around the time when the drive stoped working i think.Thanks for any help. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 27, 2006 Report Share Posted March 27, 2006 (Code 39) Reasons for this error include a driver that is not present; a binary file that is corrupt; a file I/O problem, or a driver that references an entry point in another binary file that could not be loaded.When you click on Properties for this driver, what do you see? Is it a Microsoft driver (what version/date), or is it a Sony driver (version/date)? Check if you can find any newer driver at http://sony.storagesupport.com/dvdrw/dru820adwn.htm Quote Link to comment Share on other sites More sharing options...
RyanTheWizard Posted March 27, 2006 Author Report Share Posted March 27, 2006 It is a microsoft driver. version 5.1.2535.0but i though cd drives didn't have drivers.and i was lookin through stuff and there were errors in the "devnode Flags" Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted March 27, 2006 Report Share Posted March 27, 2006 CD-Rom's do not use drivers, they use Firmware. Windows still needs a driver to interface itself with the hardware. This is usually done with the Microsoft ASPI driver.Does the Drive not appear in My Computer?If not, you can try this free app for correcting the upper and lower filter problem. Thought I am not sure if it fixes corrupt drivers. This is a WindowsXP file only, and you will need to reinstall CD-Buring software after using it. For more info, see - http://aumha.org/regfiles.php under OTHER REGISTRY PATCHES (Section 3)I would also try:start > run > sfc /scannow to repair the windows drivers. Quote Link to comment Share on other sites More sharing options...
