Service Pack 2 & ActiveX Problem
Hi All..
Have a bit of a problem... Ever since we installed SP2 on a winxp pro workstation I am not able to access Scotiaconnect.. The following are the errors that I get... I follow their instructions but still no luck... I have also tried updating to IE7 (no luck), updated all windows updates (no luck), antivirus is up to date... I would greatly appreciate some help... Thanks in advance
Your Browser and System Information
Details of your browser and system are as follows:
Platform
WinXP
Browser Type and Version
IE 6.0
JavaScript is on
Yes
ActiveX is on
No
Cookies is on
Yes
Java Applets is on
Yes
Microsoft VM is on
Yes
SSL is on
No
Items in red do not meet the minimum requirements.
How to enable ActiveX on the browser
How to test SSL on the browser
Instructions for enabling ActiveX on the IE 6.0 Browser
Check the lower right hand corner of this browser window.
If there is an icon showing a globe and the word "Internet", you are an Internet user.
If there is an icon showing two computers and the words "Local intranet", you are an Intranet user.
In this browser window, click on the Tools drop down menu, select Internet Options.
In the Internet Options window, click on the Security tab.
On the Security page:
click on the Internet icon if you are an Internet user.
click on the Local intranet icon if you are an Intranet user.
On the Security page, click the Custom Level button.
On the Security Settings page, scroll down to the ActiveX controls and plug-ins setting.
Under the Initialize and script ActiveX controls not marked as safe setting, select Enable.
On the Security Settings page, click on OK.
In the Warning! pop up window asking if you are sure you want to change the security settings for this zone, click the Yes button.
On the Internet Options page, click the OK button.
Please follow the instructions to check if SSL has been activated on your browser.
Instructions for enabling SSL on the IE 6.0 Browser
In the Internet Options window, click on the Advanced tab.
On the Advanced Settings page, scroll down to the Security setting.
Make sure the Use SSL 2.0 and Use SSL 3.0 boxes are selected.
It's for the following link
https://www.scotiaconnect.scotiabank...oamingEPF.html
It happens when I go to test the browser
