tgamble Posted May 19, 2006 Report Share Posted May 19, 2006 Upon starting work this morning I have noticed that I do not have sound.Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
-pops- Posted May 19, 2006 Report Share Posted May 19, 2006 Ensure all plugs and other things that might come loose are fully where they should be. Ensure that you have sound enabled - speakers and in the computer itself. Try a cold re-boot i.e shut down the machine and turn off the mains supply (or if a laptop, remove the battery). Leave for about 10 - 15 minutes and re-boot. Quote Link to comment Share on other sites More sharing options...
dadyassa Posted May 19, 2006 Report Share Posted May 19, 2006 Welcome to the forum, I assume you mean on the PC ?Right click on loudspeaker symbol bottom right of screen, then click adjust audio props and check that Mute is not ticked in the volume tab.Check all the connections from PC to speakers.Is volume up on speakers ?I must learn to type with two fingers ;-) Quote Link to comment Share on other sites More sharing options...
