Smart Failure
Hi,
Whenever I start my PC after checking the drive the machine shows me a smart failure warning, telling me to backup my harddrive as it will crash...can you give me any solution to that...snce I really don't want to lose my harddisk...I has my original windows in it and also most of my program!
well I am not using my PC right now as I will not start up...It is restarting while it is on the windows startup screen ("Welcome to windows") So I will not be able to test it now but if ever it says that my harddrive is not healthy what should I do?
Sorry I am stuck then. If you keep checking, one of the experts should be able to help you when they come home from that dreadful pastime called work.
Thank you for your answers! I got a new harddisk and i am trying know if i can install windows without having the serial key! Is that possible?
I don't think so, but you need one of the experts to look at this problem for you.
