robsaveslives Posted May 25, 2006 Report Share Posted May 25, 2006 I have a lexar Multi card reader (RW022-001) and i need to format compact flash cards for DOS, the problem is, i don't have the utilities disc for the reader. is there some other way i can format this card? Quote Link to comment Share on other sites More sharing options...
-pops- Posted May 25, 2006 Report Share Posted May 25, 2006 Does this help?Software and manuals can be downloaded from http://www.lexar.com/drivers/index.html - scroll down the page. :) Quote Link to comment Share on other sites More sharing options...
robsaveslives Posted May 25, 2006 Author Report Share Posted May 25, 2006 thanks, but the driver doesn't do anything for formatting, and there is no software for the reader on the site.is there any other way to format the card using Windows besides FAT? i know with the Macintosh disc utility there are a few options for DOS formatting, but i'm useless when it comes to windows Quote Link to comment Share on other sites More sharing options...
-pops- Posted May 25, 2006 Report Share Posted May 25, 2006 Well, if you are using WNT, W2K or XP you cannot format in MSDOS and have it easily recognised because these operating systems do not use DOS as their engine. Quote Link to comment Share on other sites More sharing options...
robsaveslives Posted May 25, 2006 Author Report Share Posted May 25, 2006 so i should be able to format DOS in say, windows 98? Quote Link to comment Share on other sites More sharing options...
-pops- Posted May 25, 2006 Report Share Posted May 25, 2006 Possibly but I'm not sure as it's a long time since I used Windows 9x Quote Link to comment Share on other sites More sharing options...
