KoolNeil Posted June 8, 2006 Report Share Posted June 8, 2006 Hi all.So, im going to set up a wireless network in my home but all i keep seeing are 'ADSL' wireless routers. I have cable set up at home with an optical fibre running into a Cable Modem. Are there any wireless routers that allow me to plug the ethernet cable from the modem into the wireless router and then for that to wirelessly trasmit my internet?Thanks in advance Quote Link to comment Share on other sites More sharing options...
Boa Constrictor Posted July 4, 2006 Report Share Posted July 4, 2006 I think, they're basically the same. (and I'm a complete computer idiot)I have cable and I'm using Netgear - they come in at least 3 speeds. Quote Link to comment Share on other sites More sharing options...
-pops- Posted July 5, 2006 Report Share Posted July 5, 2006 Are there any wireless routers that allow me to plug the ethernet cable from the modem into the wireless router and then for that to wirelessly trasmit my internet?Yes, I believe all wireless routers will do this. Be careful to buy a router and not a combined modem and router.Remember you will need a receiver on the computer for your wireless transmission. Quote Link to comment Share on other sites More sharing options...
