I need to switch my C drive to another drive
I recently bought another hard drive (SATA) and i installed it in my computer, thinking everything would work fine and I could just use it for storage...
But, adding that drive takes too much power and my graphics card will not run right.
I have a FAT32 partition on that drive with stuff on it already.
I want to copy my current C drive onto my E drive (SATA), turn off my computer, take out my old C drive, and be able to boot up Windows with my SATA drive as my C drive.
How do I do this? just copy and paste??
I dont need to worry about the boot loader because I am using GRUB and i'll edit it accordingly..
Well do you know how to do backup's..?? Have a backup program..?? Windows has one built in, But i don't know how well it works ....
Look through the start menu.. You'll find it.. Accessories/System tools
Sounds like maybe your power supply isn't in such good shape, Maybe you should concider buying a new one of those as well, Or else you'll be sorry later..
Thats easy, After you do the backup and shut down - set the new SATA drive to Master , Then stick it back in..
