strange shutdown problems
the who
I have windows 2000 and when I tried to shut down, the little dialog box that says "please wait" has disappeared and the computer can only be turned off by physically pressing the power switch. It still logs me off and it quits when the dialog box would say "windows is shutting down" because the desktop backround is the default blue instead of my background. I also can't log off and log back on because the dialog box has disappeared.
I thought this was an effect of recently installing the windows defender beta (why did I want that anyway?), so i uninstalled it and the problem still occurred.
When I start up into safe mode, the computer shuts down just fine.
Does this sound like a virus or is it something stupid I did?
Please help me, I don't want to reinstall windows because of this silly little problem
Hello, and welcome to the Windows Forum!
Do you have anti-virus software installed? Is it up-to-date, and did you run a full scan recently?
Do you have anti-spyware installed? (Not something useless like Windows Defender, but a serious anti-spyware like Ewido). Is it up-to-date, and did you run a full scan recently? (If "no", "no", "no", you can run an online scan from http://www.ewido.net/).
Do you have a firewall installed? If so, what, and which version?
yes, I have all of that installed, Ad aware pro with ad-watch, zone alarm free, and mcafee viruscan enterprise 8.0i. Although I was thinking about trying the ewido because in these forums everybody reccomends it.
my first problem has been magically resolved (don't ask me how). It starts up and shuts down fine now
now my new problem is the computer will boot up normally and then after a few minutes it will immeadiately power off, no shut down process. the power just gets killed. I built this computer about 1 1/2 years ago. Does this new problem sound like a hardware problem or is it still a windows problem?
I did work it pretty hard yesterday when i was working on the first problem, I probably started up and shut down over 20 times.
thanks for your help
i found the problem
one of the latches holding the CPU heatsink on broke, which allowed the cpu to get really hot and my computer turned off automatically. i used a tie-wrap to hook it back on.
and my other problem turned out to be a conflict ZoneAlarm firewall
Depending on the ZA version you have, you can find any older version here http://download.zonelabs.com/bin/free/info...eHistories.html
When uninstalling the current version, make sure that you uninstall with the /CLEAN option, otherwise you won't be able to install an earlier version. (Don't uninstall from Control Panel, but go to Start -> Programs -> Zone Labs, then right-click on Uninstall Zone Labs Security, select Properties, then change Target to
"C:\Program Files\Zone Labs\ZoneAlarm\zauninst.exe" /clean
Click OK, then uninstall from here.)
