Help! about IE links
As you know, when you link to "http:// ***.mp3", the media player9 will start up and play the mp3. (if you associate the .mp3 with mediaplayer9 in your register)
But, when i link to "http://***.xml", the IE browser itself will open the xml file and show the content of the xml file instead of starting an application. But I have associated .xml with altrova xmlspy(an xml editor) in the register. When i open an local xml file, xmpspy will start up automaticly. Why in the internet it is different? How can I modify the register to stop the IE's showing the xml file itself, but start up xmlspy to edit the xml file? just like the .mp3 page starts the mediaplayer9.
Thank you for your advice!
I think cozofdeath is right. You will have to edit a registry key.
Firefox is much easier to fix this, as you simply go into download options, and change the default program for the xml extension.
this should help you display XML within Internet Explorer, but to make it open into a defaulted program is different.
Stop. Using. Internet. Explorer!
Simple. Go for Firefox. B)
