Sleepy PC not waking up from LAN
annie_m
Hi folks. Yes I know I'm probably thick but can someone tell me how I get a pc to wake up from standby via the local network?
Ive done the box ticking thing under /Control Panel/System/Hardware/Device Manager/Network Adapters/..etc, but it stays firmly on standby when access is requested from another computer on the network. Have also tried a "ping" to the computers IP addr from the Run/CMD prompt and it stays fast asleep.
I'm sure I've just missed something very obvious.. or is this yet another bit of MS that doesn't work?? :blink:
Btw, Andsome, the cat has been nowhere near it!!! lol
  • 1 month later...
What motherboard do you have? I assume it supports Wake on LAN?
Sorry it's been a while. Have done some investigating around jumper links etc, to no avail.
The PC is an Advent 3618, motherboard is a MSi 6741 with integrated LAN. I downloaded the full manual but there are no hints there either, not even in BIOS settings. I can't seem to find any useful contact information for support, and am getting a teeny bit frustrated..
Does anyone have any suggestions?
On page 3-19 it mentions Wake On Lan settings. Looks like you need to go into your BIOS, into the Integrated Periphials section and check that it is set to enabled
Ok Nell, I missed that. Have enabled LAN PME in the BIOS (it was off). Shame it didn't make any difference tho' - i had high hopes for a minute!
