dbarks3030 Posted August 24, 2006 Report Share Posted August 24, 2006 Students in my computer class use keyboard strokes to rotate monitor 90 degrees. What are the keyboard strokes? How can I prevent this from happening? How can I undo rotation? Quote Link to comment Share on other sites More sharing options...
dadyassa Posted August 24, 2006 Report Share Posted August 24, 2006 Ask them not to do it. If you switch it off they will switch it back on again ;) I assume you have got an nvidia card.Control panelNvidea managementDesktop manageris there a tick in enable box ? maybe if you untick this it will stop them OR.....click hot keys tabopen display modeHilite... rotate displayclick addthen adjust properties to suit. Quote Link to comment Share on other sites More sharing options...
catgate Posted August 24, 2006 Report Share Posted August 24, 2006 I'm dying to suggest that you turn the tables on them, but this is not very helpful...so I won't. Quote Link to comment Share on other sites More sharing options...
dadyassa Posted August 24, 2006 Report Share Posted August 24, 2006 I'm dying to suggest that you turn the tables on them, but this is not very helpful...so I won't.teacher could do that in the adjust properties to suit bit ;) ;) like rotate screen on the space or enter key :lol: Quote Link to comment Share on other sites More sharing options...
cozofdeath Posted August 25, 2006 Report Share Posted August 25, 2006 I rotate mine by pressing control+alt+arrow key. You should be able to disable this through the registry. What type of graphics card do you have? Quote Link to comment Share on other sites More sharing options...
