bantots Posted September 7, 2006 Report Share Posted September 7, 2006 does anyone here have a home office? what do you use to clean the computer, fax machine, printer, etc. I've got canned air, a spray to clean the monitor screen, but I'm not sure what to use to clean the computer and fax machine body. Since starting a home office, I've noticed that the computer and fax have started to get a layer of oil because my livingroom(the only place I can fit all those things) is right next to the kitchen. Any help ideas to keep things clean and in order would be great! Quote Link to comment Share on other sites More sharing options...
nellie2 Posted September 7, 2006 Report Share Posted September 7, 2006 To clean the casing I usually just use a damp cloth. There is a guide here if that is any use to you. Quote Link to comment Share on other sites More sharing options...
