skype problem
ritchie888
hello
im have recently been using skype.. havnt been using it for long and dont know much about it..
but when ever i talk to my friend its constantly cracking up and going silent for a couple of seconds and going quiet at random times..
is this a connection problem or is it a microphone problem..
i believe it is my internet connection. i have wireless internet and i was hoping that there is a program or somone that knows alot about windows to help me solve this problem
me and my friend have cheap mics (non-USB) so is that the problem?
i was expecting skype to be crisp quality for talking to friends over the internet but it really isnt...
is there somthing im not doing right or somthing i can change to increase the quality..?
(another thing is that im using wireless internet and my friend isnt, would that make a difference?)
i have:
Norton internet security
bt voyager 2100 wireless router ADSL
internet with BT
i have been told many ways to solve this problem including:
configuring my firewall to skype
stopping my Wireless Zero Configuration-service (which only seemed to make my internet cut off now and again)
turning off Qos Packet
i dont know what to do now..
please help. im sure theres somthing on windows that i can do to increase the quality of VOIP.
also, if i was not using wireless internet would i get crisp pc2pc talking? and does the cheap mics have anything to do with it?
please help, i have posted this post on a couple of forums now including skype... they wernt as helpful as i hoped.
thanks in advance
Ritchie
Are you using mike/speaker or mike/headphones? My thinking here is that if you're using a mike/speaker combination there could be acoustic feedback which the Skype software is cutting off before you hear it. Just a thought.
I don't use Skype as such but I do use an Internet phone system and I found that using the facilities offered by the soundcard (mike with phones or speakers) were very much inferior to using a USB combined mike/phones headset. Best of all, though, is a USB telephone handset supplied by the phone service provider for less than £10.
If you do use a USB mike/phones system ensure that you disable Skype's ability to use the soundcard.
