NT7 Posted October 7, 2006 Report Share Posted October 7, 2006 Hello...After setting up my Windows XP...When I try to install new programs,there were formed "temp_dir" folders and these folders are not deleted automatically after installation process.For example when I try to set up MS Office 2003 it gives me the error--> "Error in opening log file.Ensure that the log file is writable.."I think that my C:/ drive is noıt writable.How will I get rid of this problem..thanx... Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 8, 2006 Report Share Posted October 8, 2006 Hello, and welcome to the Windows Forum!Not sure what it causing this? Are you installing your apps as an Administrator user? Is your file system NTFS? Quote Link to comment Share on other sites More sharing options...
NT7 Posted October 8, 2006 Author Report Share Posted October 8, 2006 Thank you very much...Yes,I am using the administrator account and using NTFS....Is there any way about the registry to get rid of this problem?An d I forgot to tell that I have packed my own XP Cd with nlite os packer and integrated the updates etc..... Quote Link to comment Share on other sites More sharing options...
Scarecrow Man Posted October 8, 2006 Report Share Posted October 8, 2006 Is this the error you are recieving?1622 Error opening installation log file. Verify that the specified log file location exists and is writable. This Microsoft Support Article may provide some options to try: http://support.microsoft.com/kb/826511/ Quote Link to comment Share on other sites More sharing options...
NT7 Posted October 9, 2006 Author Report Share Posted October 9, 2006 Is this the error you are recieving?1622 Error opening installation log file. Verify that the specified log file location exists and is writable. This Microsoft Support Article may provide some options to try: http://support.microsoft.com/kb/826511/yeah thats the message...I loooked to the link that you have given but there is said that the log file is saved in \temp folder,and my main problem is about the \temp folder too...Briefly I need to change my default \temp folder every problem is caused because of this \temp folder location... Quote Link to comment Share on other sites More sharing options...
NT7 Posted October 9, 2006 Author Report Share Posted October 9, 2006 Finally I got over the problem...I am telling the method to change temporary folder of Windows XP....First Right Click My Computer icon > Properties > Advanced > Environment you will see the tepm folder settings there > Click edit then change the folder paths as you want....Thanx everyone who are interested in this problem... Quote Link to comment Share on other sites More sharing options...
