Strange net use problem, can't delete it and can't add it!
I have a domain script which is called to make the network drives. Nothing unusual there, but for one XP Pro (Sp2) machine it seems to not register some drives like x: drive are connected to the network shares.
For example, "net use" does not list x: as being connected so I try
net use x: \\hostname\sharename
System error 85 has occurred.
The local device name is already in use.
So I do
net use x: /d
The network connection could not be found.
More help is available by typing NET HELPMSG 2250.
Look like the system is mightily confused. So I rebooted it and again got the same thing.
But the drive works, you can see it in Explorer and go into it in a cmd window and dir around as well.....
Has anybody seen this kind of behaviour before or have any idea what is wrong with it?
if you just issue the "net use" command, what is listed? Is X listed as being connected? Is X mapped to a local drive?
x is not listed and it is not connected to a local drive. It is connected to a network share and you can do
x:
dir
and get a complete listing of the remote drive. It appears in explorer but not in the cmd window's net use command. This must be a bug.
Pat Willener: thanks for the link but the user has domain admin rights and that page says that it's due to protection mode and that it will not happen to an administrator.
I will try disconnecting via explorer since it can see the drive.
