shuhornoplenty Posted October 19, 2006 Report Share Posted October 19, 2006 I am trying to install a program in my program and I get this annoying message.... Can anyone tell me what to do?"You do not have access to make the required system configuration modifications. Please rerun this installation from an administrator's account."AND I AM INSTALLING ON A ADMINISTATOR'S ACCOUNT!!! Quote Link to comment Share on other sites More sharing options...
-pops- Posted October 19, 2006 Report Share Posted October 19, 2006 Is there more than one account on the machine? If so, try installing from one of the others. Quote Link to comment Share on other sites More sharing options...
shuhornoplenty Posted October 19, 2006 Author Report Share Posted October 19, 2006 Yeah, I just tried that and it didnt work....Thanks Pops, and I'm open to any other ideas..... :0 Quote Link to comment Share on other sites More sharing options...
cozofdeath Posted October 20, 2006 Report Share Posted October 20, 2006 You may have a file or registry key that doesn't have correct permissions on it. Thats just a guess. You could check installation logs if any. You may be able to detect were exactly its having the problem with something like regmon or filemon from sysinternals. You could also try using runas to run it in the default admin account or in safe mode. Quote Link to comment Share on other sites More sharing options...
shuhornoplenty Posted October 20, 2006 Author Report Share Posted October 20, 2006 thanx to all, but i decided im just going to re-boot....thanx again. Quote Link to comment Share on other sites More sharing options...
woodchip Posted October 20, 2006 Report Share Posted October 20, 2006 If the program is on disc, copy it to Desktop. Restart in Safe mode and run setup from the copy Quote Link to comment Share on other sites More sharing options...
