WMP bad sound?
CJ550
In what format are these transfers?
Do you have the correct codecs installed to play them?
Have you tried another media player?
Is all the software and drivers for your sound card installed and functioning properly?
Have you tried updating WMP to a later version?
What is your operating system?
How do i find out this
Dont know, how do i find out what codecs i have
no, which one should i try- where do i get it
I think so
currently running version 10
XP pro service pk 2 cpu 2.8ghz 1.0 gb ram
how these help
If you hover the mouse pointer over the file in a list a box will appear giving information about the file - including its format.
Question 2 may be answered in your reply to q. 1. A collection of codecs for most media applications can be obtained from click here.
You could try the free version of Jet Audio from click here. There are a number of others.
There is a development version (beta version) of WMP 11 available. A number of people (including myself) are using this successfully.
Note that if you are loading music into your computer's hard drive without any compression, it will fill up very quickly.
