avexhype Posted October 29, 2006 Report Share Posted October 29, 2006 If I can fix this problem this forum will be the best ever, anyways, I have another computer which is currently messed up. It had a virus, (or something else, I dont remember, its been sitting there for about 5 months), so I thought if I re-installed XP it would help it, so I did....but in the middle of the installation, I was in step number 4 (the one that says installing windows) and it said setup will be complete in approximately 33 minutes, so I waited them, 2 hours past by, 4, 5, 1 day, 2 days, so I knew it wasnt working, so I just shut off my computer and tried it again, same thing, started at step number 4, and stayed there for A LONG time, then I think I remember a pop up saying there was something wrong with the virus program or something, and with the printer, anyways, so I turned it off again, and I pressed F8 to go to the Windows Menu, I pressed Repair windows XP (because the setup wasnt working as I said previously), but then it asked me for an administrator password....anyone know where I can get this? How can I install windows so I can use the PC again? Thanks. Quote Link to comment Share on other sites More sharing options...
andsome Posted October 29, 2006 Report Share Posted October 29, 2006 Were you trying to install XP over the top of the old program, or did you do a full format and then follow up with the installation? The printer and everything else should be unplugged or turned off. Quote Link to comment Share on other sites More sharing options...
avexhype Posted October 29, 2006 Author Report Share Posted October 29, 2006 ya the computer came with windows ME Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 30, 2006 Report Share Posted October 30, 2006 Let me rephrase Andsome's question: did you format the HD before installing Windows, or did you just install over the existing Windows installation? Quote Link to comment Share on other sites More sharing options...
