nikki Posted November 16, 2006 Report Share Posted November 16, 2006 Hi! I'm using an old labtop with Windows ME and I would like to transfer all my data from the Microsoft Works agenda to an external hard drive in order to save everything as I intend to change computers. I can't find any saving options...I would appreciate your help!Thanks!Nikki Quote Link to comment Share on other sites More sharing options...
AlanHo Posted November 16, 2006 Report Share Posted November 16, 2006 If you have the external hard drive plugged into a USB port - you should be able to use Windows Explorer to drag and drop the files across.Some external drives require accompanying software to be installed so the computer can recognise it. I have a drive that you can just plug into the USB port and Windows will do the rest. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted November 17, 2006 Report Share Posted November 17, 2006 I don't know Microsoft Works, so I don't know where it saves its data, but possibly in the 'My Documents' folder.One easy way to transfer files and settings to a new computer is the Files and Settings Transfer Wizard. Click here for a few articles on the Microsoft site. Quote Link to comment Share on other sites More sharing options...
