Sir Radfordin Posted January 10, 2003 Report Share Posted January 10, 2003 oi wot ya doin puttin links to some random webspace I've used :D Link to comment Share on other sites More sharing options...
Scarthy © ® ™ Posted January 10, 2003 Author Report Share Posted January 10, 2003 I don't have any webspace....Well I have 20 meg with E-Telecom, but no knowledge on using it yet...Is there a way to use FTP and my IP address to upload from my IP??? Or are there any Free webspaces that you can use to upload to???Here's a pic of a p***y close up ! ! !>> Link to comment Share on other sites More sharing options...
Tankus Posted January 10, 2003 Report Share Posted January 10, 2003 testMy Webpage Link to comment Share on other sites More sharing options...
Guest ellas Posted January 10, 2003 Report Share Posted January 10, 2003 yes sir radfordin is right just takes more bandwidth,it will work with file attacment but remember the size,to big and it will not upload. Link to comment Share on other sites More sharing options...
Sir Radfordin Posted January 10, 2003 Report Share Posted January 10, 2003 Tankus that link worked, opens up and plays in real player here. However the link is a little misleading :rolleyes: Scarthy, check with your ISP about webspace, you should be able to get something set up without too many problems.There are several free webspace providers available, but it could be more hassle than its worth unless you want to get into building sites. Even then its not the best option as you noramlly end up with loads of adverts/pop ups etc.I'll go look into E-Telecom for you! Link to comment Share on other sites More sharing options...
Scarthy © ® ™ Posted January 10, 2003 Author Report Share Posted January 10, 2003 It works Tankus...although a little slow with 56k <_> Link to comment Share on other sites More sharing options...
Sir Radfordin Posted January 10, 2003 Report Share Posted January 10, 2003 ellas - didn't let me upload a 1k .wav file so there must be some restrictions on it somewhere!Only way I can seee it is by doing an external link. Link to comment Share on other sites More sharing options...
Tankus Posted January 10, 2003 Report Share Posted January 10, 2003 Im not sure how that works....where is the sound file kept ? why does it come up my web page?....(I dont have one ?) Link to comment Share on other sites More sharing options...
Tankus Posted January 10, 2003 Report Share Posted January 10, 2003 Not worth the effort methinks Link to comment Share on other sites More sharing options...
Sir Radfordin Posted January 10, 2003 Report Share Posted January 10, 2003 Tankus, I'm guessing you've posted a link from someone else website? Did have a look at the HTML code behind your post but at this time of night couldn't get my head round it!Like you said..is it worth it?? Link to comment Share on other sites More sharing options...
