mypain Posted November 27, 2006 Report Share Posted November 27, 2006 So i have such a problemI use the WIn theme Aarustaand there is some problem - see the attached fileso in almost programs the text is black , but in applications , for example in "help and support" there is the text have thewhite color , how can i fix this in this themethk a lot! Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 27, 2006 Report Share Posted November 27, 2006 Are other themes OK?It may be fundamental fault in the program.I can't find any Google references to "Aarusta". Can you give more information? Quote Link to comment Share on other sites More sharing options...
mypain Posted November 27, 2006 Author Report Share Posted November 27, 2006 yes all another themes are all rightthere is a bug in arusta I upload Arusta here - http://getfile.biz/55021 Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 27, 2006 Report Share Posted November 27, 2006 there is a bug in arustaThe only thing to do then is inform the creators - they probably want to know anyway, if they aren't already aware of the fault. If they are aware, you will most likely get access to a corrected version. :) Quote Link to comment Share on other sites More sharing options...
mypain Posted November 27, 2006 Author Report Share Posted November 27, 2006 there is fixed wersion =) http://www.tune-up.com/services/visualstyles/?page=1thk 2 all Quote Link to comment Share on other sites More sharing options...
-pops- Posted November 27, 2006 Report Share Posted November 27, 2006 Glad you're fixed :) Quote Link to comment Share on other sites More sharing options...
