nikconsult Posted December 2, 2006 Report Share Posted December 2, 2006 hai....my name is nik...i have a problem to 'wake -up' my pc when i stand by it.....the button on my keyboard seems not function ...what should i do...before this that button and the 'Power' button can use to wake-up my pc when i stand by it...... Quote Link to comment Share on other sites More sharing options...
-pops- Posted December 2, 2006 Report Share Posted December 2, 2006 Hello Nik and welcome to Windows Forum.Is this a new problem with your computer?Has it worked previously and now changed?Is it a wired or wireless keyboard?This function is controlled by the Power Management settings in the BIOS of the computer. Check that the settings are correct and that the BIOS is functioning properly - for example a failed or failing battery on the motherboard can cause malfunctions of the BIOS settings. Quote Link to comment Share on other sites More sharing options...
nikconsult Posted December 2, 2006 Author Report Share Posted December 2, 2006 Hai -pops-..tq for your quick reply for my problem......i just use a normal pc ..not a laptop.......it aready happen before...but some time it Ok....so just now it start again...........what should i do :( Quote Link to comment Share on other sites More sharing options...
-pops- Posted December 2, 2006 Report Share Posted December 2, 2006 OK, Are you sure the battery is working correctly - does the computer keep the correct time and date or have you had any messages suggesting that the BIOS is wrong?On many computers the "Power On by PS/2 Keyboard" is disabled by default and if the battery power to the BIOS has been interrupted it will revert to the default setting - that is disabled. Have you checked that there have not been any changes in the BIOS of the computer and that the Power Management Setup is correct for the way you want it to work? If you are not sure about looking at the BIOS, I suggest you get someone else to look at it for you as you can cause damage by doing the wrong thing. Quote Link to comment Share on other sites More sharing options...
nikconsult Posted December 2, 2006 Author Report Share Posted December 2, 2006 OK, Are you sure the battery is working correctly - does the computer keep the correct time and date or have you had any messages suggesting that the BIOS is wrong?On many computers the "Power On by PS/2 Keyboard" is disabled by default and if the battery power to the BIOS has been interrupted it will revert to the default setting - that is disabled. Have you checked that there have not been any changes in the BIOS of the computer and that the Power Management Setup is correct for the way you want it to work? If you are not sure about looking at the BIOS, I suggest you get someone else to look at it for you as you can cause damage by doing the wrong thing.i think the battery work correctly.....it show correct time and date before this it already happen at the first time i setup this win Xp SP2....so i update the windows...so it function normally..i can..stand by my computer....and when i just move the Mouse or press the Wake Up button on my keyboard ..the windows can load up....but now if i move the Mouse or press the Wake Up button on my keyboard..it still can't load up the windows..so i need to restart my computer Quote Link to comment Share on other sites More sharing options...
-pops- Posted December 2, 2006 Report Share Posted December 2, 2006 Are the mouse and keyboard PS/2 or USB? Quote Link to comment Share on other sites More sharing options...
nikconsult Posted December 2, 2006 Author Report Share Posted December 2, 2006 Are the mouse and keyboard PS/2 or USB?both mouse and key board ---PS/2 Quote Link to comment Share on other sites More sharing options...
