/!\ XP pro: create two indipendent accounts
kejo
hello
i have XP Pro + Sp2 on a desktop at home.
i want to create 2 different and indipendent one each other accounts.
(as if i have installed twice windows and so i would have 2 admins)
i want an account for me and another one for my family.
don't want they influence each other..
how can i do that ?
please help me..
thanks a lot
ps: if i create 2 admins i see that one's programs are also seen in the other account and viceversa..
Most of your installed programs will go into the All Users folder. (C:\Documents and Settings\All Users\).
To change this, just cut the files you do not want to appear for all users, and paste them into the account you do want them displayed.
For example, to remove Adobe Reader from All Users, go to C:\Documents and Settings\All Users\Start Menu and cut Adobe Reader. Now paste it into C:\Documents and Settings\Your Username\Start Menu. You will also need to do this for Desktop icons.
