Still having Sound probelms
JesseJ1935
Back again, I'm still having soundproblems, i.e. the speakers and mic are dead as a dodo. I have ran Direct X this morning, results Below:
Direct X Files: The file mfc.dll is incorrectly installed in the Windows folder and should be deleted.
Sound: Failure at step 19: HRESULT = 0x00000000 Error Code.
Music: Failed on all tests.
Test Direct Play: Tests failed.
I have managed to get the Volume Controls back and everything is turned on.
How do I delete the dodgy file safely? Do I just simply search for it then delete it?
Please help someone. As always, all ideas/suggestions gratefully received.
