sarabinti Posted July 10, 2003 Report Share Posted July 10, 2003 hello all, i have win 98SE, 512 ddr. Athlon TB1.4 64DDR VC. i only have a problem when i download something (like yahoo messanger or MSN etc..) it only download half the way then it freezes though i still can access the web with normal speed but when i click ctrl + alt + del i find the thing i am downloading stopped responding. i apreciate any suggestion you may have and thank you for your help. by the way i am using Modem 56k V.90 Quote Link to comment Share on other sites More sharing options...
Guest LB Posted July 10, 2003 Report Share Posted July 10, 2003 are you using a download manager? Quote Link to comment Share on other sites More sharing options...
sarabinti Posted July 10, 2003 Author Report Share Posted July 10, 2003 no i am not. it's just the windown default.i am desperatly looking for help. thank you Quote Link to comment Share on other sites More sharing options...
Craig Posted July 10, 2003 Report Share Posted July 10, 2003 I've had similar problems with my boardband connection, but i have put the cause of the problem down to the websites and not the connection.However the software you trying to download i would expect no problem from as they are from people with a lot of money.Are you able to name anything else you have tried downloading, and if so, provide us with the link so we can have a go to rule out a possible problem with the website.We can then point the problem at either your ISP, or your computer. Quote Link to comment Share on other sites More sharing options...
AndySD Posted July 10, 2003 Report Share Posted July 10, 2003 You could try a Download Manager like Fresh Download Quote Link to comment Share on other sites More sharing options...
Boris Posted July 10, 2003 Report Share Posted July 10, 2003 I personally swear by Download Express - free from :-http://www.metaproducts.com/mp/mpProducts_...ame=desetup.exeIt's based on their (pay for) Mass Downloader product - but in its current state will do anything you need - multi-thread, AV check, resume (+ small footprint as well) Quote Link to comment Share on other sites More sharing options...
Guest northamuk Posted July 10, 2003 Report Share Posted July 10, 2003 As AndySD suggests, try a Download Manager, that, at least, will allow you to resume where the download broke off. Quote Link to comment Share on other sites More sharing options...
sarabinti Posted July 11, 2003 Author Report Share Posted July 11, 2003 thanks all for the reply.yesterday all of the sudden at a certain time i downloaded everything i need with no problems, i tried later on to download something and the problem occured, so it's almost for sure that it's the ISP problem.thanx againP.Si just started using download accelator, because i have been using it for years now. but if there is something better please share it. Quote Link to comment Share on other sites More sharing options...
