jango Posted January 21, 2007 Report Share Posted January 21, 2007 Bought my pc couple of month ago not sure if i can go wireless with it how do i know if it comes with wireless card already? Thanks Quote Link to comment Share on other sites More sharing options...
nellie2 Posted January 21, 2007 Report Share Posted January 21, 2007 If your PC is a desktop model (not a laptop) then it probably doesn't have a wireless card, you can check your hardware configuration by either downloading and running Belarc advisor or you could just go to your control panel, click on Network and Internet Connections, then the Network Connections icon and if you have a Wireless network card installed then you will have a wireless Network Connection icon in the Network Connections window Quote Link to comment Share on other sites More sharing options...
nellie2 Posted January 21, 2007 Report Share Posted January 21, 2007 Here is a screen shot that I just took of my laptop to show you what I mean Quote Link to comment Share on other sites More sharing options...
