Glasairmell Posted January 28, 2007 Report Share Posted January 28, 2007 Hi,Does anyone know of a thread they can point me to or suggest a reg edit for this.Everytime I shut down my HP XP laptop it says updates ready to be installed. I click shutdown, it installs 1 update. When I restart and go to shut down again it does it again. It is putting directories in root directory each time and not removing them.I think this started when I insalled the lattest Norton antivirus however I am not sure.Thanks for any input you can give me. :) Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 29, 2007 Report Share Posted January 29, 2007 Welcome to the Windows Forum!Is it a Windows (or Microsoft) update that your are getting, or some kind of Norton update?If it's Microsoft or Windows, then go and check C:\Windows\WindowsUpdate.log - it should give you some information on the update that failed (including the error code). Check near the bottom; check date & time of the last update failure. Quote Link to comment Share on other sites More sharing options...
Glasairmell Posted January 29, 2007 Author Report Share Posted January 29, 2007 Pat Willener' Thank you for your response.Here is a link to the log if you do not mind looking at it.WindowsUpdate.logSomethings has obviously gone wrong. Is there a reg edit I can do to stop this?Thanks! Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 29, 2007 Report Share Posted January 29, 2007 Thank you for posting the log. The information in the log states repeatedlyUpdate is not allowed to download due to regulationHere is a Microsoft KB article that describes the message: http://support.microsoft.com/kb/910340 - basically it says to use Microsoft Update instead of automatic update.Can you try this and see if it succeeds? Quote Link to comment Share on other sites More sharing options...
Glasairmell Posted January 29, 2007 Author Report Share Posted January 29, 2007 Hello,I ran the updates manually off microsoft, did not really want IE 7.0 but what the heck, and the problem is still there.The small yello icon keeps asking me when I start the computer too. It wants to install 4.0 SP2 Secruity Update (KB927978) I can click it all night and it will keep trying. That is probably where the loop is.So I turned off Auto update and the problem went away of course. So I guess I will just leave auto update off. Probably better to do that anyway.Thanks for your help so far. Quote Link to comment Share on other sites More sharing options...
Glasairmell Posted January 29, 2007 Author Report Share Posted January 29, 2007 BTW if I turn Auto update back on the problem comes back the same. Quote Link to comment Share on other sites More sharing options...
-pops- Posted January 29, 2007 Report Share Posted January 29, 2007 As an aside, I never use Auto Update. Microsoft have produced some real dogs of updates in the past - ones which have caused computers to crash, slow down or fail completely. Because of this, I will let MS tell me of an update but I always wait a few days before installing and keep a check on any reports of the update(s) causing problems. Only when there is the all clear will I download. This applies to any updates, not only the ones from MS. In fact, with other updates, I am very wary about applying them under any circumstances. If my software is working in the way I want it to, I don't seen the point in disturbing that for the sake of some (often) very minor change in the GUI or similar. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 30, 2007 Report Share Posted January 30, 2007 Are you saying that when you ran Microsoft Update, you were not offered KB927978 to install? Even under Custom mode? Quote Link to comment Share on other sites More sharing options...
Glasairmell Posted January 30, 2007 Author Report Share Posted January 30, 2007 Are you saying that when you ran Microsoft Update, you were not offered KB927978 to install? Even under Custom mode?No I am saying that after I did microsoft update from the site, it still wanted to install KB927978 on reboots and shutdowns. That seems to be the update it keep wanting to install. Sure wish I knew how to stop it. KB927978 was not one of the updates that I got off the MS site. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 30, 2007 Report Share Posted January 30, 2007 This is highly unusual - at least I have never seen, or heard of such a situation: AutoUpdate offering an update that you don't get on Microsoft Update.One question (which may or may not give us an answer): are you usinghttp://windowsupdate.microsoft.com/ ?http://update.microsoft.com/ ? Quote Link to comment Share on other sites More sharing options...
Glasairmell Posted January 30, 2007 Author Report Share Posted January 30, 2007 Maybe I need to clarify something. This is an update that has already been downloaded and ready to install. It does not say downloading updates or do you want to download this update. It just says downloaded updates ready to install.When I did the update as you asked I used http://update.microsoft.com/ Thanks! Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 30, 2007 Report Share Posted January 30, 2007 From the log you supplied earlier, it appears as if the update was not downloaded. This means that Microsoft Update should still detect the missing update and offer it.At this stage I would recommend that you download the update manually from http://www.microsoft.com/downloads/details...1B-6F18FE6921D4 and install it from there. Quote Link to comment Share on other sites More sharing options...
