larrybdl Posted February 5, 2007 Report Share Posted February 5, 2007 I tried to defrag my hd and was told couldn't access the file, windows restore window is completely blank, can't change user accounts , I've been running this system for about 1yr with auto updates enabled everything was fine, now today i can't even pass a windows validation test when it always did before. Please Help Quote Link to comment Share on other sites More sharing options...
trackrat Posted February 5, 2007 Report Share Posted February 5, 2007 You could try running sfc /scannow from the command line.This link will show you how to do it.http://www.updatexp.com/scannow-sfc.html Quote Link to comment Share on other sites More sharing options...
larrybdl Posted February 5, 2007 Author Report Share Posted February 5, 2007 You could try running sfc /scannow from the command line.This link will show you how to do it.http://www.updatexp.com/scannow-sfc.htmlThanks I've tried that along with checking reg edit as recommended by microsoft for same issues everything seems to be in place Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted February 6, 2007 Report Share Posted February 6, 2007 I think the first thing you should do is to run check disk:chkdsk /f Quote Link to comment Share on other sites More sharing options...
